Switch on/off snap/fade on cue with midi??
robdquick
Just started using FS
FreeStyler Version: 3.5.5
Twitter: http://www.twitter.com/2gmobiledj
Post by robdquick »
Is there anyway to turn on/off the snap/fade button on a cue with midi?? I can't seem to find a control for it in the list.
Re: Switch on/off snap/fade on cue with midi??
No there isnt BUT i like your idea... only i would like to have it on TUI2..
you can add a Feature request on the FSBT theres a link on top of this page "Submit a Bug report"
robdquick
Post by robdquick »
Ok, what do you mean by TUI2???
I will submit a feature request.
TouchscreenUserIterface2
robdquick
Post by robdquick »
Ahhhh ok, never used the touchscreen interface so had no idea that was the acronym for it!
