Please help me
jumpy1971
FreeStyler Version: 3.5.4
Please help me
Post by jumpy1971 »
Please help me,
I am looking for a setting for IMG Stage Line PARL36dmx.Since I'm not so good with the freestyler dmx, I do not get the channel settings / macro settings back.
Power supply: . . . 230V~/50Hz/12VA
Lamp: . . . . . . . . . 61 extra bright LEDs
Ambient temp.: . . 0 –40 °C
Dimensions: . . . . ∅116mm . 155mm
Weight: . . . . . . . . 1kg
Subject to technical modification.
All rights reserved by MONACOR ® INTERNATIONAL GmbH & Co. KG. No part of this instruction
manual may be reproduced in any form or by any means for any commercial use.
* If channel 5 is adjusted to change of colour or music control, all adjustments of channels 1 –4 will be deactivated.
0 –255
with mode 1 adjusted (DMX values 0–63 for channel 1):
0% →100% brightness of the red LEDs
CHANNEL 1: Operating modes 1–4
DMX value
0 –63 mode 1: manual colour adjustment via the brightness of the RGB LEDs
brightness of the red LEDs (R) adjustable via channel 2
brightness of the green LEDs (G) adjustable via channel 3
brightness of the blue LEDs (B) adjustable via channel 4
128–191 mode 3: automatic change between 7 colours
speed for change of colour adjustable via channel 2
CHANNEL 2: Red, speed for the operating modes 2 –4
0
1 –255
Function
with mode 2, 3, or 4 adjusted (DMX values 64–255 for channel 1):
min. speed
max. speed →min. speed
CHANNEL 2: Green
CHANNEL 5: Fast change of colour, music control
0 –255
CHANNEL 4: Blue
0% →100% brightness of the green LEDs
11 –100
192– 255 mode 4: automatic change between red, green, and blue
0 –255
64–127
0% →100% brightness of the blue LEDs
mode 2: automatic fading between 7 colours
fading speed adjustable via channel 2
0 –10 no function
fast change of colour red/green/blue*
max. speed (DMX value 11) →min. speed (DMX value 100)
101 –150
151 –255
no function
music-controlled change of colour via the integrated microphone*
max. sensitivity (DMX value 153) →min. sensitivity (DMX value 255)
Thanks for all
jumpy
