Fixture help Eurolite QDF Bar Topic is solved
npfeil
Post by npfeil »
I am using the JMS USB2DMX Pro
Manual: (German P.11/English P.24)
http://www.rh-pro.de/rh_global/ebay//Be ... QDFBar.pdf
Description: 6 Channels
Ch. 1-4 each control one Lens
Ch. 5 Strobe
Ch. 6 Progams (Internal)
I followed the tutorial as far as I understood it.
What i did so far:
1. Name it correctly
2. Found a Fixture Pic online
3. Set total Channels 6
4. Name the channels in Channel Description Locate 255 Default 0
and now its messing with the rest of my setup ( All Eurolite. 2x KLS 200 with forum fixture + QDF Bar)
Issue:
Change values on KLS alone = works great
Change values on QDF alone = works great
Fhange values on QDF after changing values on KLS = Mayhem flashing of KLS uncontrolably
DMX Channels
1. KLS 200 Ch 1-15
2. KLS 200 Ch 16-30
3. QDF Bar Ch 31-36
i am Terminating at the end of the chain
what do i need to do/change to make it work .....
in the end I want the Sound to Light from Freestyler to control all of the setup and let me be able to disable single parts of it if needed....
Please help !
Thank you,
Nik
npfeil
Re: Fixture help Eurolite QDF Bar
Post by npfeil »
found out its the same as Chauvet 4play
http://www.freestylersupport.com/wiki/f ... plications
not tested though
