When I try to download Freestyler from the server, I set a file called Setup.exe. My Norton Anti-Virus checker scans it, tells me that it has a virus in the file and it auto-deletes it.
Whats the deal? Does anyone have a clean copy of Freestyler? The Telenet download site does the same thing each time I try.
Freestyler corrupt or has a Virus?? Topic is solved
Nathanrs93
- FreeStyler Version: None
Re: Freestyler corrupt or has a Virus??
Where have you download it from exactly? Forum? Website? I'll bring this to the attention of the staff and see what's going on. Thanks for sharing
- Spirit
- FreeStyler Version: 3.5.9
hi i think its a issue with Norton..
i dont get this.. i use AVG Free..
Disable Norton , download file and install, and enable Norton again..
- FreeStyler Version: Beta
I have notified Raphael just in case.
JDK_Gaming
- FreeStyler Version: 4.1.6
my anti virus auto deletes it too
- FreeStyler Version: 4.01
It is not detected as a virus. The install is detected as unknown and I don't know why. The install has done that for a while but if you bypass the notification then all installs correctly with no harmful effects
