Does anyone know if this particular dongle works or can work with Freestyler?
Here's the link I got it from. It has all the technical specs.
http://www.sirs-e.com/st/artnet-lm3r-sirse-p-5410.html
Any help will be greatly appreciated.
Thanks.
LIGHTMOUSE LM3R Artnet to DMX
- Spirit
- FreeStyler Version: 3.5.9
Re: LIGHTMOUSE LM3R Artnet to DMX
hi this dongle works with ARTNET 1 and 2
and freestyler should support ARTNET 1,2 and 3
Dj_john24
How do I go about setting it up with Freestyler?
I wouldn't know where to begin. Are there any set instructions on how to hook it up?
- Spirit
i Realy doent have a clue.
i never used ARTNET..
but its a Lighting Protocal so i think there is more then Enough Info on the internet.
/spirit.
/spirit.
- BillsGate
- FreeStyler Version: 4.x
Can you brief explain how?
That might help other users having the same question (including me
_______________________________________________________________________
A small update:
This week my Art-net to DMX converter arrived. With DMX Workshop I got it up and running within minutes. However, signals sent from FreestylerDMX didn't arrive at the Artnet converter.
The sollution is shamefully simple: Disabling Windows Firewall for FreestylerDMX solved the problem
A small update:
My show: http://www.reflexshows.nl | My vids: http://www.youtube.com/user/the7wan
