DMX King eDMX Issue Topic is solved
nightrider666
DMX King eDMX Issue
Post by nightrider666 »
Hi all.
I purchased a DMX King brand eDMX1 (ethernet dongle which uses Artnet) to use with Freestyler. Has anyone successfully set up these two? I can't get any response from Freestyler, however I do from DMXControl. Hints on how to set up?
I also have another issue:
I am using is with 8 cheapy moving head lights
>these
http://www.ebay.com.au/itm/162-LED-DJ-M ... 2ab&_uhb=1
These were faulty when I purchased them, but am still trying to make them work.
What is wrong with them is that the dmx coding is not only reversed (lighting desk dmx code 1 responds when the dmx code on the light is 255), but also the lights only go up to 255 channels. This is causing issues when I try to run them from any software. Basically as soon as you move a slider, the lights go to that value, then bounce back to 0 and repeat.
I've worked out using the DMX King Config software that the lights will only work fine if the output is restricted to 255 channels. They also respond perfectly from a lighting desk I have.
Does anyone know how to set Freestyler to only output 255 (or less) channels?
Re: DMX King eDMX Issue
Drop a line at dmxking.com the team will give you the best help if you don't get a reply here...
Sent from my Windows Phone 8X by HTC using Tapatalk
voxbox
Post by voxbox »
nightrider666 wrote: 02 Sep 2013, 08:23 Hi all.
I have the same problem. Did you get it solved?
Return to “DMX Interfaces”
