for instance, i wanna create a light show for a band.. the opening song i want the lights to slowly fade in- how do i do that?
thanks
how do i make LED fade effects for a sequence? Topic is solved
- FreeStyler Version: 4.01
Re: how do i make LED fade effects for a sequence?
Open a new sequence slect the fade in time that you want then set the lamp channel to fade, and the proper color channel to on. You can then add steps to create whatever look you want.
