This is the fixture file I've been tweaking on. 16 channel mode - access to every LED channel, program and color macro it has. I used the Macro page for all the programs as well as a few extra quick macros for Red, Green, Blue, Purple, Sound Mode, and All Off to reset all the channels to 0.
This is the version I'm using in our live shows so the tweaks to the Macros were done to make it perform better in a dynamic setting. I finally worked out getting the unit to comply with Master Dimmer and Blackout by using the Shutter on the same channel as Strobe. Otherwise you had to open the Shutter channel before it would allow the Dimmer to work and that was a major PITA creating and using Sequences.
Hope it helps someone else out there to enjoy this fixture!
American DJ Mega24 Pro
- UniCav
- FreeStyler Version: 3.5.2
Mega 24Pro (16ch Mode).pff- American DJ Mega24 Pro - 16 Channel Mode with Macros - Complies with Master Dimmer & Blackout
- (89.21 KiB) Downloaded 102 times
