Elation Platinum Spot 5R Pro Topic is solved
DoeorDie
Post by DoeorDie »
Hello, I'm looking for some help with this fixture. Has anybody already created a profile for it?
I've attached the manual.
Thanks!
platinum-spot-5r-pro-user-manual-v1.0.pdf
(1.68 MiB) Downloaded 92 times
Re: Elation Platinum Spot 5R Pro
Post by Jan_K »
Think it is in the complete fixture library.
viewtopic.php?f=23&t=4528
DoeorDie
Post by DoeorDie »
Sounds great! I'll check it out.
Thank You!!
