Hey I need some help:
I'm subbing for a friend, who's wife just went into labor, for a wedding on Saturday. He has a variety of non-DMX lights: Pin-spots, Small PAR cans, a couple strobes and a Chauvet color bank. He's using an elation 8 Channel patch box w/ interfaces with an 8 channel elation control box.
I noticed that the elation control box has a DMX jack in the back. Can I plug that into freestyler and use it to control the lights? If so ... how?
Thanks!
tjw
Elation patch/ control box non-dmx lights
- FreeStyler Version: 3.5.2
- Spirit
- FreeStyler Version: 3.5.9
Re: Elation patch/ control box non-dmx lights
hi
if you add some more info about the units he's using i can take a look..
URL , PDF, image...
URL , PDF, image...
Spirit:
"Patch Box": Elation Professional 8 Channel Relay Pack.
"Control Box": SC-8 Elation Professional Pattern Stand By T16 Control buttons.
The lights are American DJ
Is that good?
tjw
Is that good?
tjw
- Spirit
hi
if i google i get the same results with both units..
and i dont see a 3pin or 5 pin XLR plug on them..
only on the SC-816 Controller i do see a XLR plug but its used for a Footswich...
Hey thanks anyway. For what it's worth, on the back on one side you have the interface cable (which looks just like printer cable). On the other side you have a 3 pin plug, next to the fuse. If that helps, thanks, if not, thanks anyway for running this down for me. I appreciate it.
tjw
tjw
Come to think of it, it is probably the XLR plug.
- Spirit
yes the xlr is the 3-pin plug..
i also lookt if the D-SUB connetor worked on 0-10V but thats not the case.
otherwise you could used a Demultiplexer....
