are 20 cues enough for you? Topic is solved
Andymann
Post by Andymann »
hi threre,
so i'm just starting to explore the possibilities if freestyler and i came across the maximum of 20 cues.
that is quite a small number in my opinion.
i am planning to run a fix installation in a bar with freestyler and will have about 20 groups of spots and moving heads minimum. how am i supposed to control all these with only 20 cues?
(please think of the maximum necessary: fading lights at the bar, some programs for a group of moving heads, etc...)
did i get it rigght that the cue somehow is the basis of all operations?
how do you deal with that?
Re: are 20 cues enough for you?
save a list of twenty then create a new list save it and then use the fast cue switcher! within the cue list
