Hi there.
I have my MIDI controller set up with nearby buttons for tap tempo, manual trigger, and disable tap/trigger - but I can not find the disable tap/trigger option/button in the FreeStyler software itself.
Does it exist? or is this only controllable remotely?
Thanks.
Is there a Disable tap/trigger button in FreeStyler? Topic is solved
- Mattotone
- Android Dev (Moderator)
- FreeStyler Version: BETA
Re: Is there a Disable tap/trigger button in FreeStyler?
Right click on tap i believe.
lindsayward
Thanks!
That looks like it, but the behaviour is a little unexpected. I'm running this test in a VirtualBox VM (Win 7 on Mac host), so it could be different...
When I right-click it, it will restore back to normal not immediately, but as long as the tempo currently is (i.e. at the time when it would next advance the sequence). This makes sense, but isn't what I would want.
The manual "light" (indicator) goes on (orange), so it doesn't look like it does at startup when it's on normal (no light). I have reported this on the bug tracker.
But it does work - it goes back to the speed set in the cue window.
