Chauvet Pin Spot
tjw
Chauvet Pin Spot
Post by tjw »
Dumb question:
Is the Chauvet Pin Spot a DMX fixture? I have been looking at them and no where in their description does it say.
Thanks!
Nathanrs93
FreeStyler Version: None
Re: Chauvet Pin Spot
Post by Nathanrs93 »
If it doesn't actually say in the manual or there's no 5 or 3 pin DMX connections on the back, then no. The only way to control it then would be a relay pack via dmx, which would turn it off and on.
tjw
Post by tjw »
Thanks Nathanrs93. I've just been looking at it on Quibids as something I might want to bid on, and the description and photo of the item says nothing about it.
Nathanrs93
No problem, happy to help 8-)
