Submaster speed
skatejack
FreeStyler Version: 3.4.8
Submaster speed
Post by skatejack »
In the submasters used only for "movements" would be useful that the bar did not control the "intensity" (because it makes no sense), but that would control the "speed" of the sequence is running.
Re: Submaster speed
hi
i see you problem i would also like to have this optional.
i think i allready made a Feature Request for this.
so we need to wait before the devolper will add this feature..
but in the end i also like them seprate. as i use a Midicontroller to control the submasters.
and i can change it the way i like to have it.
/Spirit
Nathanrs93
FreeStyler Version: None
Re: Submaster speed
Post by Nathanrs93 »
Yeah, I think this would be a useful feature as it's difficult to find it on the cue list, if you have loads running at the same time. :/
Boone
FreeStyler Version: 2.96g
Re: Submaster speed
Post by Boone »
I like this idea to !!! When will this be possible...
Re: Submaster speed
lol 4 years after date.
but this feature is allready! added.
right mouse click on a submaster window.
and enable "slider control speed"
and "leave speed "as is " " will keep the speed value when you select a other sequences.
otherwise the speed will jump back to 100%
Return to “Ideas and Remarks”
