DMX values over SendMessage Topic is solved
sa1n
Post by sa1n »
Hi there!
I'm looking for a way to send DMX values directly to freestyler, that means just that I want to set an output channel for a specific fixture. I used the code sample above and I currently have the following code:
Code: Select all
        private void ButtonClick(object sender, RoutedEventArgs e)
            byte[] dmx = new byte[] { 255 };
            FsSendMessage fsSend = new FsSendMessage();
            //fsSend.SendMessageFunction(2, 1);
            fsSend.SendChMessageFunction(dmx,1);
Code: Select all
using System;
using System.Runtime.InteropServices;
namespace Freestyler.NET.Wrapper
    public class FsSendMessage
        //COMPILE AS X86 otherwise pointers need changing
        //For use with WM_COPYDATA and COPYDATASTRUCT
        [DllImport("User32.dll")]
        public static extern int SendMessage(int hWnd, int Msg, int wParam, ref Copydatastruct lParam);
        [DllImport("user32.dll")]
        public static extern int SendMessage(int hWnd, int Msg, int wParam, int LParam);
        static extern int FindWindow(string lpClassName, string lpWindowName);
        private const int WmUser = 0x400;
        private const int WmCopy = 0x4A;
        private int freestylerConnected()
            int ihandle = FindWindow(null, "FS");
            return ihandle;
        private static Int32 VarPtr(object o)
            GCHandle GC = GCHandle.Alloc(o, GCHandleType.Pinned);
            IntPtr ptr = GC.AddrOfPinnedObject();
            GC.Free();
            return ptr.ToInt32();
        public struct Copydatastruct
            public Int32 DwData;
            public Int32 CbData;
            [MarshalAs(UnmanagedType.I4)]
            public Int32 LpData;
        public void SendChMessageFunction(byte[] DMXvalues, int functionCode)
            Copydatastruct cds;
            cds.DwData = functionCode;
            cds.LpData = VarPtr(DMXvalues);
            cds.CbData = DMXvalues.Length;
            int hWnd = freestylerConnected();
            if (hWnd != 0)
                SendMessage(hWnd, WmCopy, 0, ref cds);
        public void SendMessageFunction(int command, int value)
            int iHandle = freestylerConnected();
            if (freestylerConnected() != 0)
                SendMessage(iHandle, WmUser, command, value);
Btw. I'm a c# developer. How can I send a dmx command?
Many thanks in advance!
Android Dev (Moderator)
FreeStyler Version: BETA
Re: DMX values over SendMessage
Post by Mattotone »
Is the correct method, if your having issues try using the dll file i uploaded.
Ensure you compile your app x86
sa1n
Post by sa1n »
Could you give me an example? I.e. send the dmx value 130 on dmx channel 5.
The program works fine with the standard functions.
Post by Mattotone »
is your application compiled as x86? The pointers required for dmx values only work when compiled for x86
to set just ch5 i think you need to send an output mask first. should be explained in the tcp/ip pdf in the fs directory.
also you can try this viewtopic.php?f=38&t=5111&start=10#p21032
sa1n
Post by sa1n »
Yes, my application is compiled as x86. Is there an example?
Post by Mattotone »
:fs:
Freestyler Connection Demo.rar
(77.76 KiB) Downloaded 120 times
sa1n
Post by sa1n »
Wow! That's really great :) Many thanks!
