hello ,
for our little band we use 4x led par56.
if i press key "1" , the programm 1 on cue list start.
if i press key "2" , the programm 2 starts and so on...
and we play our cover songs.
And now my question.
is it posible that if I press for exmample the key "b"
and than all pars lighting yellow.
and only if i press the key and if I left the key the normal programm starts again.
i will use it for example for the song bon jovi - its my life
bam , bam -> Yellow yellow
iiiiiits my life.... -> normal programm
Thank you!
Flash light with PAR LED
- Mattotone
- Android Dev (Moderator)
- FreeStyler Version: BETA
Re: Flash light with PAR LED
Sounds like you need to make use of overides.
