I've been trying to create a fixture for an RGB DMX Interface controller, but I've had no luck as I'm not sure how to do RGB in fixture creator. I believe if you look at the manual that it's a 6 channel fixture and can control up to 8 on one pack, so it means you will have 48 channels if controlled individually.
Does that mean the interface picks this up? Or do I have to add the fixture 8 times?
Here is the manual: http://imgur.com/DuPgtoZ
Could do with it asap if possible
