Sound 2 Light
Nathanrs93
FreeStyler Version: None
Sound 2 Light
Post by Nathanrs93 »
Hey,
I have a question in regards of Sound 2 Light. I have some of the dynamo party scanners which I've realised aren't the best scanner in the world, but cash isn't great at the moment. I've come to realise that I want to run them on Sound 2 Light in freestyler, but I've never used it before so not sure where to start?
If the sound is coming from the sound system and I have them running through to freestyler, do I need a cable to my mic input for the sound 2 light program from the sound desk? Is it also possible to save certain sound 2 light modes on cuelist buttons if i liked them? so i could play them again at a later date?
any info is helpful, as i will be testing to make sure this works soon. thanks
Re: Sound 2 Light
hi there are differny ways you can use S2L.
read this:
http://www.freestylersupport.com/wiki/sound_2_light
Nathanrs93
Re: Sound 2 Light
Nice one, spirit. Thanks :D
