Another issue with this interface!
I'm running:
FS 3.5.4
Windows 7
Upon opening FS, I get an error saying 'Interface Not Found'.
I've installed the driver for the device and tried running FS as administrator but with no luck.
I'm assuming from the select interface list I should select 'Monacore 510'?
Any help greatly appreciated.
Thanks,
imgStageLine DMX-510USB - No Interface Found
- FreeStyler Version: 3.5.4
- FreeStyler Version: 3.5.5
Re: imgStageLine DMX-510USB - No Interface Found
I had to manually install the driver from the supplied CD
works fine, as long as you run it in admin mode
(Cant get mine to run with FreeStyler though, it randomly flashes - but is fine with supplied IMG software)
let me know if you need me to explain the steps in detail...
cheers Paul.
cheers Paul.
Hey,
can you help me out.
i am also using FreeStyler 3.5.5. I updated my Operation System to Windwos 7 Professional 64 bit. I installed the Driver and Software. After Starting the Programm i changed the Interface from demo mode to dmx510usb and save the Option.
When I Change a value from my Par64 the lamp ist refreshing all the time. Is there a cheat to get run this Software? On my Notebook (Win7 64) the Software is running without refreshing all the time.
Please help.
Please help.
