Monacor 510 not found to freestyler 3.5.4 Topic is solved
funfair
Post by funfair »
Hello,
I had downloaded and installed the freestylers version 3.5.4 on 13.07.2013! When you start to get a window opened where it was "Interface Not found"! I had downloaded the driver for my interface "Monacor 510" and it still does not work!
tintin2005
Re: Monacor 510 not found to freestyler 3.5.4
Post by tintin2005 »
hello there.
i have the same problem.
i installed the last freestyler version and when i choose dmx 510usb dongle it says " no interface found".
can you help?
regards
tintin2005
tintin2005
hello again.
doesn´t anybody have the same problem?....
can somebody give me a link to download an older version of freestyler that works with this interface?
i would be gratefull.
regards
Nathanrs93
FreeStyler Version: None
Post by Nathanrs93 »
If you wish you can do a fixture request on the BUG tracker and then hopefully the developer might add it in for you :)
EDIT: BUG Tracker here
Perhaps you have to use an alternative name in the list but its compatible with the Monocor
Sent from my Windows Phone 8X by HTC using Tapatalk
Return to “DMX Interfaces”
