ArtNet -> Eurolite DMX 512 Pro
antons
Post by antons »
Hello,
I've got an Eurolite DMX 512 Pro interface and would like to use it via ArtNet. Freestyler supports my interface but the ArtNet to DMX doesnt seem to. Is there a way I could get it to work? Or do you know another tool which can do that? Or do you know how I can send values directly to the Interface so I could write something myself?
Thanks,
Anton
Re: ArtNet -> Eurolite DMX 512 Pro
yes indeed i see it..
but the Enttec Pro use the same FTDI chipset so you can try to select the enttec pro as interface and see if that works..
(i think they use the same chip)
antons
Post by antons »
Thanks! I'll try that tomorrow.
antons
Post by antons »
I tried it now but somehow I cant use the enttec pro. This seems to be a bug. When I select the enttec the controls like comport etc. of the last selected interface arent changed and when I restart ArtNet to DMX it tries to use the last interface again.
Return to “DMX Interfaces”
