How can i set Pan Tilt that goes until 127 Topic is solved
david007
Post by david007 »
I've got a fixture wich pan and tilt go from O~128 the center is 64...
How can i set this in the fixture creator?
Thanks in advance!!!
Re: How can i set Pan Tilt that goes until 127
Post by Jan_K »
Hej David
The Pan and Tilt goes from 0 to 255 and can't be limited.
Do you have a link to a user manual so I can see if it is possible to make a work-arround.
Eventually also a fixture file if you have created one. (pff)
Jan
david007
Post by david007 »
Hi Jan,
i'll send you the fixture this evening.
The device i want to control is a Lightmaxx Pegasus pro600 laser.
Can you give me your e-mail where i can send the fixture file...
Thanks in advance!
Greatings,
David
hi
yes indeed most Laser have the X/Y set from 0->127 manual control and 128->255 automatic control.
but there is nothing change this on Freestyler...
i do this with macro's ...
for a Example look at this fixture file
viewtopic.php?f=61&t=2952
and you can upload the fixture file on the Forum if you create a .PFF.
(FILE->EXPORT)
Post by Jan_K »
Hej again
Lasere are a bit complex to control decently.
There is a tutorial on the wiki with a laserworld
I would not place the X,Y movement on pan and tilt but on the gobo wheel.
Gobo1: X movement, Gobo1 rotation: X rolling.
Gobo2: Y movement, Gobo2 rotation: Y rolling.
Gobo3: Rotation.
And then I would use some icons to place the gobo fader in right, center, left and auto mode.
All the patterns I would place as macros.
You can upload you fixture here (as pff file)
david007
Post by david007 »
Pegasus Pro 600 RGB.pff
(337.45 KiB) Downloaded 78 times
Here's the fixture i made...
Post by Jan_K »
Hej David
I have been playing a bit with your fixture file just to show an other way to do it.
Lasers are a bit difficult to create fixture for as they have a lot of functions which are not covered by a normal fixture configuration.
This also makes them a bit difficult to operate as some of the faders and icons infront of the faders don't tell the correct control function.
Have a look
Pegasus_Pro_600_RGB_JK.pff
(408.86 KiB) Downloaded 83 times
david007
Post by david007 »
Jan,
thank you for adjusting my fuxture...
It works better this way!!!
Kind regards,
David
Post by Jan_K »
If you have the last patterns then please add them and upload the fixture again.
I will add it fixture collection.
