FS for iPAD.... is it available and does it support EV3D
Uriahdemon
FreeStyler Version: 3.5.5
I Use FreeStyler for: Band
Post by Uriahdemon »
Hi All,
I have searched the forums and think this might be available but the threads do not cover the info I need succicntly so apologies for perhaps posting a repeated request.
I have just purchased an iPAD and am looking to use it while working away for working on my shows. I currently use a laptop to run FS and EV3D but the iPAD would be far more convenient.
The download page states the downloads are available for most windows versions so my first question is what do I download and use for FS.
My second question ..... can I use EV3D on an iPAD and how do I do it.
As usual I am really grateful for any help in advance.
Rgds Mac
Android Dev (Moderator)
FreeStyler Version: BETA
Re: FS for iPAD.... is it available and does it support EV3
Post by Mattotone »
Hi Mac,
Freestyler & EV£D are both windows products (Mac with emulation) and unfortunately do not support Ipad, there is however a remote designed to work with IPAD to control Freestyler.
There is no method to create shows, sequences etc on your ipad and upload them to FS at a latter date, although that would be great.
Matt
buttza
FreeStyler Version: 3.6.4
Twitter: twitter.com/@buttza
Post by buttza »
You could try using Touch OSC for the control aspect of FS.
You can really use M3dEV on the iPad unless you are using Air display and set the ipad up as a second monitor. I used to do this when I wanted to control the cue list remotely.
Uriahdemon
Thanks both for the replies. Mattotone, where do I find the controller you refer to. Could you possibly give me some more info on it please....??
lindsayward
I Use FreeStyler for: Church
Post by lindsayward »
Hello Uriah...
iPad apps are all found on the Apple app store through iTunes. Here is a link to the FreeStyler remote on the app store website: https://itunes.apple.com/au/app/id417748124?mt=8
You download and install it on your iPad using the iTunes software, or directly through the iPad using the "App Store" app. (This one is not free, by the way.)
Uriahdemon
Thanks Lindsayward, I will give it a good look at over the weekend. Thanks for taking the time to get the info over, much appreciated.
Rgds
Mac
djharryg
Commited FS Forum helper
FreeStyler Version: 3635
Re: FS for iPAD.... is it available and does it support EV3D
Post by djharryg »
I installed it onto my ipad. How do I get it to work?
Freestyler: V3.6.35
