Hello,
I am struggling to find any user manuals or fixtures already created for the Chauvet Navigator Plus (CH 636x) have already been down the Google route several times with no joy.
Can anyone point me in the right direction?
Chauvet Navigator Plus Topic is solved
- djSupport
Re: Chauvet Navigator Plus
I've looked and looked too, there is only one option... and thats by using a 4 channel generic fixture from the forum and using the sliders on the right hand side when the fixture is selected, if you move one of them and the fixture pans record that channel (1 to 4) and the same for tilt, then one channel will be be colours you find the channel that controls colours and move it slowly recording the value of the slider as it gets to a complete colour for example 15 for red 30 for yellow and then the last slider (channel) will be the strobe and shutter values....
- djSupport
its more time consuming but its easier than you think to do that and get the values rather than from the manual I've setup nightclubs without manuals utilising this technique...
