If you guys could send me an email with an explaination on h
Jaykie
Post by Jaykie »
This is from the old forum
Tom_the_LD
I find that only having 20 cues in a list isn't very good. I appreciate that you can hame multiple lists, but I would like to use Freestyler at school for shows and it is not so easy to change lists halfway through the show.
Perhaps expand the cue list? OR what would be fanastic is like a more theatrical style cue list whereby you record the Ques in a list then run through them by a 'GO' button which could be assigned to something like the spacebar.
To me, the current 'cue' list is more like an effects section wherby you record effects and stick them into that list and run through them. I think a proper Cue list would be spectacular, and you MIGHT get mroe people wanting the software to use in theatres and stuff....
Return to “Ideas and Remarks”
