Crazy Idea
jopoloco
Crazy Idea
I'm new to freestyler and i'm wondering if there is a way to take a song and put it in a time line, and then add dmx values to that time line at certain points to create a light show just for that song so that every time its played it plays exactly the same lightshow. I know it would be time consuming to do that for every song in my library but It would be a great option to at least be able to do it to all my crowd favorite songs, In this age of progression I think it would be another step forward for DJ's. Just a thought.
- Mattotone
- Android Dev (Moderator)
- FreeStyler Version: BETA
Re: Crazy Idea
If you use virtual Dj there is a plugin which interfaces with Freestyler to do this.
jopoloco
Re: Crazy Idea
Thanks for the info, I found the plugins only there are no tutorials on how to get them to work. i'm really not tech savy so I've tried to just work with the plugins and its driving me crazy. Does anyone know where I can get more info. Thanks
DJDaveSA
- FreeStyler Version: 3.6
Re: Crazy Idea
Let me know what you want to do and I can try assist and give you examples of the code you put in VDJ.
jopoloco
Re: Crazy Idea
I would like to know how to insert a sequence or cue button into a song at at particular part of the track, have it play for 5 seconds and then turn off. Can I insert more than one sequence or cue button at a time? how do I save track so that every time I play song it will remember lighting sequences?
