Laserworld CS-500 RGY & Laserworld CS-1000 RGB
Dr.Johnson
Post by Dr.Johnson »
These fixture files aren`t perfect because a lot of the channels have multiple functions
For instance, the pan is centered at 0 then goes left as the dmx number gets higher. when its all the way left it will go to the right.
When the far right is reached, the laser takes over and flips the pan over automatically from left to right. faster as the dmx number gets higher.
This is the same with tilt, zoom, rotation, hight, width and wash
this is why i personally dont use the xy pan/tilt controller built in with freestyler, but i just do this manually with the upper right menu.
If any one knows a solution for this problem please let me know. ill try to fix it.
the gobo`s and colors do work perfectly
the gobo pictures are included in the rar file. as is the fixture picture
Laserworld CS-1000 RGB.rar
(55.05 KiB) Downloaded 216 times
Laserworld CS-500 RGY.rar
Laserworld CS-500RGY
(55.62 KiB) Downloaded 167 times
Re: Laserworld CS-500 RGY & Laserworld CS-1000 RGB
Hi, Exported PFF's contain all image files they are just like a zip there is no need to upload rar's :)
Dr.Johnson
ah! i didnt know that, thanks :D
Post by Jan_K »
Hej.
I just tried to import the CS-1000 RGB.
Got the messages "Invalid picture"
Dr.Johnson
Hi Jan,
i will look into this
Return to “Lasers”
