Hello All
I have been trying to make a new shape for a Hollywood party but with no luck.
I want a shop that gives me the Hollywood left to right that can be flipped on one light so it crosses.
Has any one done this in the past? everything i try just fails and i can not get my head around it
any help would be amazing
New shape Topic is solved
- Mattotone
- Android Dev (Moderator)
- FreeStyler Version: BETA
Re: New shape
For such a simple effect why not make a two step sequence? Step one one light left and the other one right. Step two fade to the oposite way
