Hi Freestyler community a pleasure to greet you and to thank you for providing such an excellent program! The e used several times and I to run rather than. The problem now is that it will go down again as I formatted the pc and when I'm installing will not let me include the 3D viewer. I guess it's because the page took the 3d viewer Nicolaudie to the address you gave. I would like to know if there is way to incorporate the 3d viewer otherwise. Prove install it separately but I worked. I hope answers.
PS: I apologize FOR MY BAD ENGLISH.
regards
Freestyler not include the 3d viewer Topic is solved
Nathanrs93
- FreeStyler Version: None
Re: Freestyler not include the 3d viewer
If you want the 3D easyview software then you can download it from here: Click here
I recommend that you download the BETA version of the software as it corrects the problems with certain things when using it with FS. Need any help, then let me know.
Note: If you do download the BETA version, you will need the normal version FIRST before you download the BETA.
Get confused or need help setting it up, give us a shout.
/Nathan
/Nathan
Howltaker
Nathanrs93 Hi thanks for your answer! Now I have the magic, but my question is ... How do you merge with Freestyler so to speak? Because I'm installing two separate things. I install the magic in the folder freestyler or as I do?
Nathanrs93
If I remember correctly you need to install it in the C:/ (Primary hard drive), if it does it correctly I think freestyler picks it up automatically. I honestly can't remember
I'll have a look for you when I get 5 mins as I'm trying to sort a lot out at the moment.
