touchscreen question... Topic is solved
joedigitaltv
Post by joedigitaltv »
when using a touchscreen with FS is it possible to push multiple buttons at the same time? i would like to be able to use flash buttons on the override buttons as well as control my submasters too.
tks in advance,
jd
Re: touchscreen question...
hi
i have tried it with my laptop with touchscreen.
i can Zoom in and out with two fingers on IE but it seems FS doesnt support Multi touch.
but just for the info Flash buttons doesnt realy work good on a Touchscreen.
so i do not recommend to use a touchscreen for this..
i only use it to controll the SMintensitie and to toggle between Overridebuttons..
for all the other controls i use the BCF2000 (Midi controller)
