submaster window gone! Topic is solved
joedigitaltv
Post by joedigitaltv »
i am using the most current version of software and have had no problems.
out of nowhere i now cannot get the submaster window to appear.
when i push the button for it on the menu bar... the cue window shows up... same thing when i push the cue button... the cue window pops up..
what have i done? any help would be great as i need to program for a show tomorrow:)
tom
Re: submaster window gone!
hi look at this
http://www.freestylersupport.com/wiki/s ... references
here you can Reset the Window positions.
i think if you do this the window will apear again.
joedigitaltv
tks that did it. appreciate the help so much.
