Keyboard shortcut to jump to next sequence Topic is solved
chriswattsuk
Post by chriswattsuk »
I know that you can create a keyboard shortcut to play a particular sequence in the Cue window, i.e. map the '1' key to play sequence one, the '2' key to play sequence two etc. But is there a key to play the 'next' sequence? I have a foot controller that I can map to a keyboard key, but there is no keyboard function as far as I can tell that works like a 'Go' button triggering the next sequence in my cue. Any help much appreciated!
Kings
Commited FS Forum helper
Re: Keyboard shortcut to jump to next sequence
Post by Kings »
Search for GoMonkey on the forum. It's an addon to FS and allows you to create stacks of cues that you can trigger and play sequentially.
