Confused about steps! Topic is solved
chriswattsuk
Post by chriswattsuk »
I have a newbie question! I've started to create some basic sequences and am wondering, let's say I want to create a sequence consisting of one light (parcan x) very slowly fading from 100% to 0%, whilst another light (parcan y) does some other stuff. I'd need to add new steps in to do the colour changes etc for parcan y (I assume), but when the new step begins, the action in the previous step seems to be cancelled?
Is there a way for a previous step to keep doing it's thing whilst other steps kick in?
Chris
Nathanrs93
FreeStyler Version: None
Re: Confused about steps!
Post by Nathanrs93 »
You don't always need a new step. I myself sometimes put some things on the same step i.e par cans, moving heads, etc
It all depends what you are doing and what you are planning on using it for really. I find ORB (override buttons) useful for moving heads, scanners, etc to change gobos and colours as it's set to a keyboard shortcut.
/Nathan
