Hey guys I think this was in a older version but I cant seem to figure out how to make it do this now.
I think you use to be able to set 2+ lights to a single point on the floor then lock there X/y together so they pan and tilt as one spot
Can we still do this?
I have 4 moving heads I'd like to control the X/Y together after setting them all to one spot of the Dance floor!
Thanks Guys!
Moving Head Spot Light options? Topic is solved
djkrazy
Re: Moving Head Spot Light options?
I would like to do this too!
Sent from my SM-N900T using Tapatalk
- Spirit
- FreeStyler Version: 3.5.9
hey its possible..
open the pan/tilt window.
first set the light to on point.
then press the Button with to arrows pointing Down/rightside.
this way you can set the Absosulte or Relative feature.
