Issue loading Override buttons via TCPIP Topic is solved
DaveLegg
Post by DaveLegg »
Hi all,
I'm attempting to build a custom wireless touchpanel solution for a nightclub, it's going well so far, and I have the panel sending commands to FS without any problems. To make it more flexible, so that changes to buttons don't need to be made on both FS and my software, I'm trying to load the list of cues and overrides using the protocol provided. I'm having issues with loading the names of the overrides, cues load fine.
When I connect with a raw session using Putty, and issue the command FSBC001000, I get the expected list of cues in reply, when I issue FSBC002000 to get the list of overrides, I get nothing back. FSBC003000 also responds correctly.
Does anyone have any idea why I'm not getting a response?
Thanks,
Dave
Android Dev (Moderator)
FreeStyler Version: BETA
Re: Issue loading Override buttons via TCPIP
Post by Mattotone »
i can confirm FSBC002 FSBC006 and fSBC007 do not return results
001 Cue captions
002 Override button captions
003 Cuelist captions of current page
004 All cuelist captions
005 Cue status
006 Override buttons flash/latch setting
007 Override buttons status
008 Group names
009 Group status
010 FreeStyler version
011 Submaster names
012 Submaster status
013 Submaster intensity
DaveLegg
Post by DaveLegg »
So this is a bug I assume? I'll stick to hard-coding the buttons for now, they won't be changing that often, and hope that a fix comes along sooner than hard-coding the buttons becomes an issue.
using the new /restricted switch in FS you could do this touch panel system using just FS and the touchscreen2 interface!, look at this post on the FS Facebook page I posted https://www.facebook.com/#!/photo.php?f ... =1&theater
