Scanic Astute 150 Pro - Freestyler DMX Fixture
joshua2007
Post by joshua2007 »
here is my work. If someone like it. :D
Astute 150 pro.zip
(25 KiB) Downloaded 45 times
Re: Scanic Astute 150 Pro - Freestyler DMX Fixture
Post by Jan_K »
Hej Joshua.
I just had a fast look on your fixture.
You should update the info in it so other user don't get confused.
The info is that it is a Stairville and it uses 12 channels created by Onge.
And have a look on the "Channel description"
The names are not updated and all default values, except ch7, is 127.
Finally there are no values in the macro.
I think that is wrong.
If you need help then let me know :)
