Hello!
I am relatively new to DMX lighting and Freestyler etc.. I have 3 chauvet colorstrips and googled for help with freestyler when this appeared. I saw that the user "Shannon D" uploaded the .pff file of preset macros, and since he/she claims they are for 3 colorstrips, just what I need, I decide to download the file.
The Problem:
I have the file downloaded, now I do not know how to use it.. I would like to enjoy the 90 macros Shannon D created, yet I do not know how. Do I have to import the macros into freestyler somehow?? When I double click it, it opens fixture creator, but the 90 macros are not in freestyler.
I understand this is very basic DMX & freestyler stuff, but bear with me as I am very new to this. If you can help me, please comment below. Thank you all and I am a happy new member for the community!
Help with .PFF files and Freestyler
- Mattotone
- Android Dev (Moderator)
- FreeStyler Version: BETA
Re: Help with .PFF files and Freestyler
you need to move the pff file into the freestyler fixtures directory.
then add the fixture using freetylers Add/Remove fixtures menu
hockeybeast
Ok, I did that, then inserted the 3 colorstrips, but when I click the macros button, here is what shows up.. This doesn't look like 90 macros that the user said he made for colorstrips, unless there is something I am missing..
- Mattotone
hey may have used the new formulas, which will allow combinations of macros. these combos may add upto 90. they can also be displayed in colour and gobo pickers
- Mattotone
iv opened the fixture and there is indeed 90 macros. unfortunately some of the "macros" are blank spaces used for positioning the buttons
hockeybeast
Ohh I see. Ok well thank you for your help!Mattotone wrote:iv opened the fixture and there is indeed 90 macros. unfortunately some of the "macros" are blank spaces used for positioning the buttons
