Help I have a problem when I change from one cue
to another cue the previous cue appears to keep running.
I play in a band and use freestylerdmx to control the bands lights so have
5 or 6 cues for each set so I need them to change from one to the other
I am running the latest version of freestylerdmx
Cue's
- Mattotone
- Android Dev (Moderator)
- FreeStyler Version: BETA
Re: Cue's
what do you mean by "change from one cue "? do you start another cue, and stop another? or simply start another cue?
are you switching fast cues, and the previous cues still run?
Any who...i recommend GoMonkey it was designed around your type of usage
- Kings
- Commited FS Forum helper
Re: Cue's
It sounds like you are switching from one sequence to another and the latest sequence is overriding the previous (it may appear to be running but the DMX signal has 'stalled' on the last value sent). This is something called HTP...Highest Takes Precedence whereby FS will always perform your latest command. A classic example is when you swap from say a scanner to a RGB par can. The mirrors on the scanners stop moving and the colours, gobos and everything else no longer change.
- Kings
Re: Cue's
As Matt says, GoMonkey may suit your needs as you can create a list/stack of cues that you can trigger sequentially during a performance. Essentially you can pre-program a whole show (or song) and just use one button to change the lights at certain times during the performance.
- Mattotone
Re: Cue's
No Helpfile im afraid, although there's a quick video showing how to create shows.
As far as midi goes, MIDI has been built into GoMonkey and you should be able to use freestyler MIDI and GoMonkey Midi simultaniously
