Hi folks...was playing around with TouchOSC and for some reason I can no longer get the overrides screen to pop up? Everything else works fine but when I click on the override icon the edges of FS desktop changes to another shade of grey (as per normal) but I just can't see the pop up screen?
I've tried attaching another monitor to see if I've accidentally placed it elsewhere by extending the display and also reinstalled the latest version of FS.
So before I start rebuilding FS by adding my show files to a 'virgin' FS, does anyone else have any ideas as to what may be happening? Is there some sort of hide overrides window command that I've accidentally initiated?
Thanks in advance!
Can no longer view the override window?
- Kings
- Commited FS Forum helper
- Kings
Re: Can no longer view the override window?
Found it! Was on some imaginary extended display north west of my primary screen. No idea how I did that.
- dmxlighting
- FreeStyler Version: beta
Hey kings
How u getting on with touch osc?
Did u work out that u can have multiple pages?
Just right click on the very top of the template and click add page.
- FreeStyler Version: None
Hey,
If you find there's any windows that you can't see when you've been using extended display or they've just disappeared for some reason, then you can reset them if you go window>reset windows positions.
/Nathan
/Nathan
- Kings
Thanks Nathan...that's exactly what I needed to know!
- Kings
Hey DMX...multiple pages are great. I've also discovered the Midi to DMX function so now I can create a control to adjust a single DMX channel, in my case the flash rate of a strobe. Once I'm finished ill post a screen shot of my OSC page.
- dmxlighting
Hi kings
My osc set up is currently 3 pages
1 is submaster controls and override buttons and some other controls
2 is override controls for movers
3 is all 24 midi to DMX sliders
I'm looking forward to seeing what u have done
Lee
Lee
