I have fixture files for ADJ Mega Par and Tri Par that show the intensity percentage on the icon for the fixture on the freestyler backgound. How do you set this up for other fixtures, as I have made and adapted some creator files for other lights that have an intensity channel, and would like the same on them. Also some over fixture files show, other graphics when sound active etc, how is this done ?
thanks in anticipation
Intensity level showing on Fixture Icon on Freestyler
timebankdisco
- Spirit
- FreeStyler Version: 3.5.9
Re: Intensity level showing on Fixture Icon on Freestyler
hi
if you create your fixture the correct way, all the parameters should show the correct way.
there is no special way to do this, fs does this automaticly.
look at this page http://www.freestylersupport.com/wiki/f ... eator_help
here there are some examples how to create differnt types of fixtures.
/Spirit
/Spirit
timebankdisco
Thanks have worked my way through tutorials, and have defined in fixture creator intensity channel and min and max values, but percentage display still does not show on icon on background, anything else I should be looking at ?
timebankdisco
Got it sussed, fixture image was on a white background, intensity was there all along, just not visible on white, put a black box bottom left of fixture image, and now visible.
