One-channel Mobile Color only showing on strobe [Fixed]
lindsayward
Post by lindsayward »
Hi there.
My RGB par cans work fine in EasyView, but...
I have 2 Mobile Color fixtures, which are 1-channel color changing lights with 14 preset colors. The fixture files are available for BOTH FreeStyler AND Magic 3D EasyView, but I only see the light in EasyView when the channel value is up at strobe. Actually the light doesn't have a strobe option - just slow and fast color cycling.
I would like to be able to see the colored beams in EasyView... Any ideas how?
In FS, the file is "Mobile Colour", under "JBSYSTEMS" folder. In EasyView it is "Mobili color_1CH" under "ACME\Intelligent". I don't know if these are the perfect match, but they look the same to me - EasyView shows the 14 presets on channel 1.
Nathanrs93
FreeStyler Version: None
Re: One-channel Mobile Color only showing on strobe
Post by Nathanrs93 »
Hey,
What you mean you only see it when it's up at strobe?
Upload both files and the manual and I'll take a look for you. See if I can sort it :)
/Nathan
hi this issue is caused by Nicolaudia 3d View.
you need to Copy the .EXE and/Or a .DLL from the beta Version to the version you get from FS and it need to be solved but i'm not sure which .DLL it needs to be.
Nathanrs93
Oh that, it's in a zip folder. I did an announcement about it and how it fix it :)
Here:Read me
It's the MEVP.zip folder in the beta folder when you've installed it, then you need to extract it within the freestyler folder, it then should work properly. Any problems, let me know.
/Nathan
lindsayward
Thanks!
I had actually seen that sticky thread already, but I thought it was only for people who couldn't see any light at all, not just for one fixture. I figured since my other fixtures worked, it was something wrong with the fixture, not the whole program...
I notice now (unlike before, I believe) that if I close 3D EasyView with the regular Windows X, then it won't start properly again until I restart FreeStyler. If I close it with the 3D button in FS, then it's fine.
Nathanrs93
lindsayward wrote:Thanks!
Sorry that's my fault I should have mention it was for both so I'll change the sticky thread. But make sure you copy all the files from the 3D easy view BETA folder to the freestyler folder, as you are replacing the old 3D files which doesn't work if you get me (the standard issue that comes when you download freestyler for the first time). I should have said that as well :lol:
If you need any help or are confused about what I've said then I'll post some pictures.
/Nathan
PS: Just remember if there's any .zip folders to extract the files within the freestyler folder as well, otherwise you will get errors and it won't work as I'm pretty should you've gathered by now ;)
lindsayward
Thanks Nathan. It is working, so I don't think I need anything more. I appreciate your willingness to help!
Nathanrs93
Welcome. Anytime. :)
/Nathan
