Backgrounded FreeStyler and Hot keys
rafaelmagic
Guys,
I am a live performer, I use Winamp to control about 30 mp3s in a live show.
I use a basic led par to light my stage. Its DMX capable, I just never used DMX.
I have been messing with FreeStyler but is their a way that I can have FreeStyler running in the background and Winamp as the active window.
Winamp for example can be in the background, behind multiple applications and the keystrokes are recognized. I just want the ability to have Winamp as active, FreeStyler in the back and be able to control both applications with keys from my keyboard.
If someone can help, I will appreciate it.
Rafael
Rafael
- Hambone
- Band Member
- FreeStyler Version: Beta
- I Use FreeStyler for: Band
Re: Backgrounded FreeStyler and Hot keys
Unfortunately there's not really a way to make FreeStyler respond to keyboard shortcuts if it isn't the active window. Your best bet would be to get a MIDI controller (options include any MIDI capable keyboard, or a dedicated controller like a Korg NANO, or even a footswitch like a Behringer FCB-1010 or ART X-15 UltraFoot) and configure it to control FreeStyler.
http://two-for-flinching.com
rafaelmagic
Hambone,
Thanks for your time.
I like the Midi Controller, If I use a midi device like the Korg Nano can FreeStyler be backgrounded?
Is their a device smaller than the Korg Nano?
Also thanks for the links to the hardware, I only have two led fixtures, no fancy moving lights. The footswitch hardware is impressive but overkill. Though it might be an opition if I ever get more lights.
I am currently looking at a script using AutoHotKey. I will allow a user to send a keystroke to a backgrounded application. Reading tutorials but so far I can't make my script work.
I actually just want to press button on my keyboard and send the hotkeys to the backgrounded FreeStyler.
Does anyone have any AutoHotKey or AutoIt experience or sample script for FreeStyler backgrounded? Or know of a midi device smaller than the Korg Nano?
Rafael
Rafael
rafaelmagic
Opps forgot to add.
Does anyone know if the Worlde Controller 9 will work with FS??
http://www.youtube.com/watch?v=xUaFQS6a2dQ
Its small and will work for my purposes.
- Hambone
- Band Member
Looks like you could do what you want with AutoHotKey (nice find, looks very handy!). Here is a script for you to try - modify it as necessary:
In this example, we've created hotkeys for Alt-a, Alt-b, the letter z, and the 1 key on the numeric keypad.
I haven't installed AutoHotKey yet and have not tested this script, but it should work. Just change they keys as needed for your setup. I would highly recommend setting modifiers instead of just mapping direct normal keys, because the hotkeys will send to FreeStyler any time you hit them. In the example script above, if you were typing in Notepad while FreeStyler was running, every time you hit the z key it would send to FreeStyler as well as to Notepad - this could be confusing
Good luck!
Code: Select all
;Define the way a window's title is matched - in this case, the window's title must start with the give string
SetTitleMatchMode,1
;Create hotkeys
;If the user presses "Alt-a", send "a" to FreeStyler (without quotes)
!a::
IfWinExist, FreeStyler 512
ControlSend,,a,FreeStyler 512
return
;If the user presses "Alt-b", send "b" to FreeStyler (without quotes)
!b::
ControlSend,,b,FreeStyler 512
return
;If the user presses "z", send "z" to FreeStyler (without quotes)
z::
ControlSend,,z,FreeStyler 512
return
;If the user presses 1 on the numeric keypad, send 1 from the numeric keypad to FreeStyler
Numpad1::
ControlSend,,{Numpad1},FreeStyler 512
return
Good luck!
rafaelmagic
HamBone,
That sends a command to FS ONLY when its Active and not when its backgrounded on Win 7.
Im currently looking at this Tutorial for reference for a backgrounded application:
http://superuser.com/questions/368633/p ... 141#371141
I'll mess with it and report back, however I am not a script person. Maybe you can help and take credit for it at the FS Wiki. =)
rafaelmagic
Guys,
Made a minor tweak to the code provided above and it works on my computer. I have WINAMP active, and FreeStyler in background (not active) and it sends hotkeys. Even when FS is minimized.
This will come in handy if your midi controller doesn't work, its a backup.
Go here for directions on AutoHotKey:
On Step #4, ignore the webpage and paste the Code below. Save and run (right click). Of course you can modify your hotkeys and the code below.
Code: Select all
settitlematchmode,2
;Create hotkeys
!a::
controlsend,,a, FreeStyler 512
return
!b::
controlsend,,b, FreeStyler 512
return
z::
controlsend,,z, FreeStyler 512
return
;If the user presses 1 on numeric keypad, send 1 from the numeric keypad to FreeStyler
Numpad1::
controlsend,,{Numpad1}, FreeStyler 512
return
rafaelmagic
Setup:
Download and install AutoHotKey
http://www.autohotkey.com/download/
Create a new Text File, .txt file and Rename it to have the .ahk extension. File in picture named "GetMediaKey".
Right-click the file and select Edit Script
Copy and Paste the Code Above (In Previous Post)
Save
Right-click the file again, this time selecting Run Script
The script is active as indicated in the Windows tray:
Save
glafont69
Hello,
A little update to make your hotkeys working in background with freestylerX2 and autohotkey.
See the script bellow.
The only remaining problem is the flash buttons that need a "hold" command.
settitlematchmode, 2
F1::
IfWinExist FreeStylerX2
controlsend, , {F1}, ahk_exe FreeStylerX2.exe
return
F2::
controlsend, , {F2}, ahk_exe FreeStylerX2.exe
return
F3::
controlsend, , {F3}, ahk_exe FreeStylerX2.exe
return
F4::
controlsend, , {F4}, ahk_exe FreeStylerX2.exe
return
F5::
controlsend, , {F5}, ahk_exe FreeStylerX2.exe
return
F6::
controlsend, , {F6}, ahk_exe FreeStylerX2.exe
return
F7::
controlsend, , {F7}, ahk_exe FreeStylerX2.exe
return
F8::
controlsend, , {F8}, ahk_exe FreeStylerX2.exe
return
F9::
controlsend, , {F9}, ahk_exe FreeStylerX2.exe
return
F10::
controlsend, , {F10}, ahk_exe FreeStylerX2.exe
return
F11::
controlsend, , {F11}, ahk_exe FreeStylerX2.exe
return
Numpad1::
IfWinExist, FreeStylerX2
controlsend, , {Numpad1}, ahk_exe FreeStylerX2.exe
return
Numpad2::
controlsend, , {Numpad2}, ahk_exe FreeStylerX2.exe
return
Numpad3::
controlsend, , {Numpad3}, ahk_exe FreeStylerX2.exe
return
Numpad4::
controlsend, , {Numpad4}, ahk_exe FreeStylerX2.exe
return
F1::
return
F2::
return
F3::
return
F4::
return
F5::
return
F6::
return
F7::
return
F8::
return
F9::
return
F10::
return
F11::
return
Numpad1::
return
Numpad2::
return
Numpad3::
return
Numpad4::
return
glafont69
Another trick I've been working on tonight.
I have different shows with different speeds that need to have S2L work on divided beats.
Off for high speed shows and divided by 4 in certain shows.
here is a way to change it while you select your show !
F3::
WinGet, hWnd, ID, A ; memorize what window is on top
IfWinExist Sound 2 Light - 2.0.0.3
SetControlDelay -1 ; May improve reliability and reduce side effects.
;select you choice by uncomment
ControlClick, x40 y210, Sound 2 Light - 2.0.0.3
;ControlClick, x65 y210, Sound 2 Light - 2.0.0.3
;ControlClick, x90 y210, Sound 2 Light - 2.0.0.3
WinActivate, ahk_id %hWnd% ;Set back the active window
return
else
MsgBox, Sound to light Off
return
return
enjoy !
F3::
return
else
return
return
enjoy !
