Input Past End Of File Topic is solved
Trucktrail7
Post by Trucktrail7 »
Hi everybody!
A few days ago I built a profile for a Chauvet Intimidator spot LED 150. I went through and added gobo pics, colors, the whole 10 yards. I saved the profile and then exported. I went to load the fixture into Freestyler and I received a message "INTIMIDATOR SPOT LED 150.fxt : Input past end of file". I'm not sure what I did wrong but I would like to find out so I don't mess up any future fixtures. Thanks for any help you can provide! I attached the .pff file that was exported for anyone that would like to review it.
Re: Input Past End Of File
hi
the input end of file doesnt make it possible to look in the File anymore.
But i realy like it you tried to create your own Fixture file :fs: (Trucktrail7 Rocks! ) ;)
But this fixture is allready created and can be download for the Complete LIB file.
viewtopic.php?f=23&t=4528
Trucktrail7
Thank You! I didn't realize it was already there. I will go get it then. I will tell you what I noticed. If I build a profile without adding all the gobos and colors (simply add up total channels and change the descriptions), the profile works. But, like on this one, when I added colors and gobos, thats when that message came up.
