"Type Mismatch" error Topic is solved
romch
Post by romch »
I just "upgraded" to the newer beta version on freestyler and now get a "type mismatch" error for the Martin SCX500 and EFX600 fixtures. Anyone know what is wrong or why this is happening? Is anyone else getting this error?
Re: "Type Mismatch" error
try opening in fixture creator then if it opens re-save over them
thelodgemd
Post by thelodgemd »
I opened and edited a fixture created before I upgraded to new version - after saving the edited fixture and trying to open it again, I get a "type mismastch" error. The old fixture profile opens correctly - but if you edit an old one and then save it then you will get the "type mismatch" error when trying to open.
Post by Jan_K »
there are an error in these two fixtures.
Which one are you looking for.
