So envision 8 pars, 4 pars, 2 groups. Vertical on left and right, red, blue, green, yellow.
If I apply the sine fx to the left 4 which is 12 steps in the fx generator and I'm happy with that. Is it possible to mirror the fx of the left 4 to the right 4 without having to regenerate another fx cue just for the right > in essence having two cues.....I only want them to use one cue to do work "together"
I guess I'm asking, is there a way to slave the right 4 to the left 4's pattern?
Chris
Applying a pattern from one set of pars to another? [Solved]
- Commited FS Forum helper
- FreeStyler Version: 3.6.2
- FreeStyler Version: None
Re: Applying a pattern from one set of pars to another?
I believe this will help you out with your problem, but if you have anymore questions then please ask.
Click Here
Nathan
Click Here
Nathan
ah ok, in transparent mode you select and deselect the fixtures without overwriting the preprocessed bank.....that was helpful and shined a light......I'm good to go.....thanks for the the help.
Chris
Chris
