Hello!
The following problem:
I create in a transparent mode of Freestylers on the integrated movement pattern editor movement for my 6 Heads. Everything to OFF (no snap / no fade).
If I do this then save it as a scene in the editor and then upload it runs perfect!
When in a cue will only load in the corresponding Pan & Tilt position which is stored as a start down, but left no movement.
Even when loading this individual cues in the sequence player.
Wanted to program everything transparent, I have several sections where I can easily retrieve colors, gobos and movements and change so easily.
I've already read some tutorials / views, but since I'm not out of it smarter.
Does anyone have an idea?
Thanks in advance!
Playback of preprogrammed movement-shapes FS 3.5.2
beamshape
- FreeStyler Version: 3.4
- I Use FreeStyler for: TV Broadcast
