I DJ using Virtual DJ on my Macbook Pro (Intel based) in it's native OSX. I would LOVE to run VDJ in the same manner, but sadly, there is no Freestyler code that works directly with OSX. There's lots of expertise out there, so can you help me learn more about how to run Freestyler on my Mac while keeping my OSX coded VDJ? I would really like to use the built-in interface that VDJ has with Freestyler, but I'm not sure if I can do this with the VDJ in OSX if Freestyler is running in a separate partition (or window)... I'm sure you'll know best.
Thanks in advance!
Best way to run VDJ in OSX while also running Freestyler Topic is solved
Nathanrs93
- FreeStyler Version: None
Re: Best way to run VDJ in OSX while also running Freestyler
Hey,
I understand that freestyler only runs on windows only, I'm afraid. If you wanted to use it on the Mac it would have to be used on parallels to get it to work. If have any questions then please don't be afraid to ask.
Regards,
Nathan
Regards,
Nathan
