Can't add fixtures - help! Topic is solved
johnnotestine
Post by johnnotestine »
I just reinstalled freestyler and now I can't install fixtures from the user created ones on the forum. I am trying to add ADJ UVLEDBar16, ADJ Megapixel, and ADJ Revo 4. When I click on the fixture profile it now says "Input past end of File".
Thinking it may have something to do with the upgrade, I installed freestyler on a different computer for the first time. The exact same things happens when I try to add the fixture profiles.
Am I doing something wrong? Is this a bug?
Re: Can't add fixtures - help!
try downloading the big zip file full of files as alot of them were re-saved from older incompatible versions... and try re-downloading the file from the forum...
