This is from the old forum
LJ Dennis
in the program i miss Masterfader(groupdimmer) and 20 cues(programs) are not very much...
Greets LJDennis
More Cues and Masterfader Topic is solved
suemac
Re: More Cues and Masterfader
HI,
The number of cues available will probably keep me from using FS.
I want to use it for theatrical performances and I can easily use 20 cues in the first act.
If it is a fast paced play, I could use 20 cues in the first scene!
Mac
Mac
- djSupport
use the quick fire cue list loader and you can have 20 x 20 cues instantly at ur finger tips!
Tom
How can I use this?DJ Support wrote:use the quick fire cue list loader and you can have 20 x 20 cues instantly at ur finger tips!
- djSupport
in the cue list click SAVE CUE then do another cue list by click the folder with the cogs on and clear list now fill it up again and save it all saved cues will be in the "Fast cue list switcher" on the cue window click a cue will open it up instantly thus having infinate number of cues.................
pasaporto
djSupport wrote:in the cue list click SAVE CUE then do another cue list by click the folder with the cogs on and clear list now fill it up again and save it all saved cues will be in the "Fast cue list switcher" on the cue window click a cue will open it up instantly thus having infinate number of cues.................
yes but.... what if you are triggering via midi...... ..you need more cues or something so you can trigger everithing via midi
kered
I have been using the sub masters screen as this allows you to add a different cue list of 20 sequences to each of the 20 sub masters. As you have 20 sub masters that will give you 20 X 20 sequences this gives a total of 400 sequences (i use these as my stage scenes). I am using a Behringer BCF2000-WH midi controller that will allow me to assign a midi fader to each master fader in FS and two midi buttons to step next and previous through the sequences in a given sub master channel.
If a stage scenes has a lot of light changes I simply program them into one sequence (I have set a limit of 400 steps per sequence) and then use the manual trigger to step through them. (this is also assigned to a midi button)
If you think of it in 3 levels you have a sub master (I use to control the overall intensity of the lights) that is made up of several sequences (each main stage scene/set on stage) that is made up of several scenes. (light changes for the stage scene, this could be flashing or change positions of lights to follow your actors around the stage)
