touchscreen driver shuts down FS.
rickwwallace
Just started using FS
Post by rickwwallace »
I found my problem to be the touchscreen driver. I am using a HP slate with win 7 professional. When the touchscreen service is running you cannot load or save a sequence or cue (even with a mouse). When you shut down the service and use a mouse everything works fine. Has anyone had this problem and gotten it to work or is this a bug. I ask because it worked OK for about a month then started giving me problems. Now I cant use it without shutting down the touch screen service. I only use this tablet for Lighting and would really like to find a workarround or fix for this. Thanks
